gniknave »
https://forums.nicoclub.com/gniknave-u19269.html
Sat Mar 04, 2006 11:17 am
When it comes to the timing chain guides, ignore anything the dealer says. They're very misinformed when it comes to the older Q45 models as it is. Most have never done an engine rebuild on a Q45 to know exactly what happens when a chain guide breaks.
You have to figure, with all the newer vehicles in Infiniti's lineup - all of which use metal backed guides, the 90-93 Q45 if THE only one that used plastic. Most of Infiniti's service advisors, technicians, and parts counter people weren't with the company back then. Most people that own 90-93 Q45's don't take them to dealerships because of the cost of repair. You figure, if the uninformed owners of these cars drive them, yet can't really afford to maintain them, when the car dies they can't afford to fix it. It never see's the dealer.
Point being, it's a lot more cost effective for Infiniti to train it's employees on the current vehicles and most recent ones, rather than the older Q45's that don't come to the dealer much anyway. Can't blame Infiniti for that, but they shouldn't let their people give out misleading information either. Especially if it's not something they really know about.
In the mindset of an Infiniti service employee (or any other dealership) [Parts, Technician, Service Writer], you either replace all the parts while doing a certain job, or they won't warranty anything. For example, when replacing the transmission, the dealer will want to replace the radiator as well to make sure the transmission cooler cools the new transmission properly.
Same with the chain guides. One would think that if you're replacing the timing chain guides, then you'd replace the timing chain. The dealer will do it this way or just not warranty the work. In some cases, they might do it their way or no way at all.
Anyway, you have the proof of actual experiences of the people that own these cars and a few of us have actually done the chain guide job successfully on annumber of occasions. I think it's better to follow the advice of those who have done the job and experienced the results after the fact, than to listen to the dealer who's primary job is to sell as much as possible - since they're all commissioned.
The chains don't need to be changed, but do change the oil pump chain. It's easy to do and would only take you 5 minutes. If you need help with the job, post in Infiniti Online Mechanic (after searching first) and we'd be glad to help. If you're doing this yourself or having someone else do it, please make sure to read through the posts about chain guides on here so you know what - and what not to do. Search for posts by username: Tangalora
They will be most informative.
