As far as the car, I will be driving my '95 Nissan 240sx. As the car sits now:'95 Nissan 240sx SESR20DET S13-blacktopGreddy M-Spec IntercoolerHKS Wastegate actuatorHKS SuperSequential BOVB&M Short ShifterSpec Stage 3+ ClutchZ32 Fuel FilterWalbro 255 lt/hr Fuel PumpER Spec hot-pipeMR downpipeTestpipe (God I love Florida)Koyo RadiatorFAL Dual 12" FansHelical diff from S15 SpecRTokico Illumina front strutsKYB GR-2 rear strutsUnknown springsNismo Tension Rod bushingsB&M Short ShifterSpec Stage 3+ ClutchER Radiator Cooling PanelForge coolant hosesMiata BatteryNismo Motor and transmission MountsGreddy Boost GaugeGreddy Oil Pressure GaugeGreddy Rocker-Arm StoppersCusco Rear Sway Bar
Waiting to be installed:Tien Tie-Rod and Tie-Rod EndsBattle Version RUCA'sBattle Version Rear Toe RodsCusco Front Sway BarZ32 front brakesSteel Braided Brake Lines Steel Braided Clutch LineFuel Pump hardwire kitKYB AGX Rear StrutsSPLParts Subframe CollarsSteering BushingsMR Exhaust ManifoldMR Turbo ElbowCircuit Sports steel braided Oil/Coolant lines
Looking to buy:Racing seatscamlock-type 5-point harnasses
I also need to figure out some brake-cooling, probably going to go with some sort of laundry-induction. I will also do the hood-mod for better cooling. Hoping my car holds together
