doing conversion, having trouble
takumi604
Car: girls
sup peepshaving a little troublei am doing a 5 lug conversion, on the front right now, i have taken out the strut and unbolted the brakes. now the only thing i am having trouble is taking off the knuckle of the steering rods, and the A arm. i have take out the pins and the nut. but it won't come off, its tight *** on there. any suggestions in how the hell to take it off, i tried using the U shape fork to pry it by it ain't budging!, anyone!!! i'm in the NY / long island area! if some want to meet up and helpthanks
Takeoff
Car: 1993 240sx
You mean you can get the knuckle off the lower control arm? If you have a mallet pound on it a bit. Sometimes the knuckle get pressed on the ball joint pretty tight and needs some force and vibration to get it loose. good luck
SmithSR
Car: 240sx
Hammer on the CAST IRON knuckle nearest the spot that holds the ball joint.
The ball joint will come free.
