akshun wrote:how much more fluid is there after the 5 quarts? and is it as easy as dropping the pan and out it comes? or is there a drain bolt as well??? sorry for the noobish type q's...im only really well versed with integras
I don't know exactly how many quarts the J hold but it's somewhere around 10-14 quarts.
The J30 has a drain plug on the transmission pan just like on the oil pan. Pull the plug and you can drain about 5 quarts. Then you can drop the transmission pan by unscrewing the screws around the edge of the transmission pan. You might have to slightly pry it off to break the seal. Then you can get to the transmission filter which is held on by 3 bolts iirc.
Install the new filter, clean off all the old gasket off the transmission pan edge (with puddy knife), clean off the magnet in the bottom of transmission pan, clean out inside of transmission pan with lots of brake parts cleaner, install transmission pan with new gasket that comes in transmission filter kit, re-install transmission pan drain plug, measure how much fluid you drained out and refill with that much new fluid.
Take short drive then park on level surface, check for leaks, and with the engine running, check transmission fluid level and add if nec.
