Mehhhh-beelwesso wrote:as opposed to 4 way?
Oh yeah I definitely know about nissan guages ... shall we say optimism? But since my car is a Z32 with a stock Z32 gearbox and speedo sensor and wheels then from the speedo guages perspective it's at least consistent... it's the ECU's perspective I am worried about.Carl H wrote:nissan tachometers are off by a fair bit...i see this alot when recalibrating tachs for rb swaps.my own car reads 8k on the tach but datascan sees it as 7600; a good 300rpm difference.what happens is that even tho ecu will revcut the engine is still spinning so it wont stop exactly at the revcut...so when seting revlimit you should set it a hair lower than actual desired.as far as the speec cut goes, same deal...nissan speedos are a hair bit inflated from factory so while it might read xx mph, it is really only going yy mph; remember that tire and wheel sizes as well as final drive differences will skew the speedo output.when i swapped a r33 auto rear end into my car (4.36final vs std 4.08) i had to order a 21 tooth pinion for the speedo to get a correct readout.
Sure let me elaborate...Carl H wrote:werd.not sure what you mean tho about the ecu's perspective...the speedsensor isnt a major load sensor, its there for speed cut and for decel (iac duty cycle modification).sorry, can you be clearer?
The speedometer gauge was factory calibrated for the following: X = 300ZX wheels/tires, Y = 300ZX N/A Rear End Ratio, and Z = 300ZX Speedo Signal
In my setup, X, Y, Z have not changed at all: the car is a 300ZX Z32 NA using an Z32 N/A M/T, speedo sensor, and stock VLSD, with stock wheels/tires. So the gauge is accurate for this setup.
However the ECU is expecting a different X, Y, Z for the Q45: maybe the overall tire diameter is close but I'm not sure... I know the diff ratio should be way different. So in theory, the ECU will think I am going faster or slower than my real speed and will speed govern at the wrong limit.
As a contradiction/counterpoint: Now there is another interesting tidbit: On every nissan speedometer I have taken out before (B13 sentra, S13 240SX, Z32 300ZX) I see a marking that says "1024 RPM = 60MPH" or something similar. If this is true and consistent, then it seems that Nissan sets their speedo sensors up such that what comes out of them is a signal with 1024/60 HZ per 60MPH, in which case both any contemporary nissan gauge and ECU will be reading the right speed (so long as the speedo sensor itself is calibrated for the tires and diff ratio consistent with the 60MPH=1024 RPM rule). I can't confirm this, but it seems logical. I think that is why they used to sell different gearsets for their speedo sensors (they may have been color coded too) to compensate for swaps in differentials, rather than just recalibrating the speedo itself.
Perhaps I would if I could get my question answered. No response through email, nor on the forums. Here it is, one more time, plain and simple:elwesso wrote:just letting everyone know that i am waiting on 1 other ECU and I'd really like to get everyone that wants in to hit me up now, or as soon as possible, it really makes it easier for me.
As I understand it, it is not the tune but the application of the right foot that determines MPG, besides idling time, fuel quality, etc.z1 zonly wrote:
3) Detune for better MPG
