homeslicej2 »
https://forums.nicoclub.com/homeslicej2-u54419.html
Mon Mar 29, 2010 1:18 am
plenty of people just bolt the J30 diff into the S13 with no issues. They use larger washers to give a bit of support to the bushing. I used the SPL alum. bushing kit bc my J30 diff was missing one of it's bushings when I got it from the junkyard. Also, the stock S13 open diff has no bushings, it's solid iron that bolts to the subframe, so using alum. bushings on the J30 to secure it will not make a difference in noise, ride, etc. There's also no risk of tearing the stock J30 bushings and dropping the diff (which can supposedly happen) if you use an alum kit with longer bolts (like SPL's).
