Doing a heart transplant...
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
Getting ready to swap motors out one chucki coupe to another. I found a perfect lowmilage 89 coupe in SC no rust whatsoever. Was wondering is there is anything I should replace while the motor is out?? Nothing is wrong except a slight idle problem at times. I was thinking IACV and gasket, Coolant temp sensor, and injector o-rings, just to start. Anything else I should change. Thanks
Koshin
Was thinking maybe do the water pump and oil pump?? Should I replace a lot of the stuff while its out. I didnt know if there was a list of stuff that SHOULD be replaced when the motor comes out. Trying to take care of things while its being swapped. I am kind of nerotic and am just trying to take care of the SR. Just wondering what others have done before. Thanks
T-rev
oil pump and water pump. So much easier to get the front cover off, when its out of the car. Next time I pull my motor I will replace the timing chain, guides, and tensioner, so I would recommend doing that too, depending on your funds/nerocious
