Doing a CA swap...
roe_wedge
Car: 1990 240 SX S13
I got some extra cash from doing this swap.. what are the first upgrades you guys reccomend ?
Juujai
wrong forum but new fuel pump as usual, probably a front mount, injectors, rom tune, z mafs
240DRFT
clutch, exhaust, turbo timer, boost controller.
574-240sx
Car: Nissans, Toyotas, Subaru
get the motor running stock then upgrade from there. I believe the most common upgrages are FMIC, bov, fuel pump, and SR T25.
roe_wedge
oops sorry on the wrong forum i thought i really was in CA haha. I got the FMIC , and the exhaust covered.. well catback.. should i get a new manifold or anything like that?
rico05
Car: 1992 RMS13 w/ CA18DET
No, the only ones that are cost efective are SSAC ones, and they have yet to be endurance tested. Plus, the stock one flows fine. Look into a SR T25G. I have one, and it is a little laggy, but at the 10psi I am running now, I should be around 200rwhp. Make sure and pick up some gauges straight away. My first mod on my CA was a fuel pump. After that it was a boost gauge, followed by a turbo timer. I then bought a turbo back exhaust. After that, I purchased a ARC intercooler and hard pipes, but you already have that, so forget it LOL. Next up on my to do list (after Xmas shopping) is a new water pump, oil cooler, and koyo rad. Then, headgasket, 2G DSM blue top 440cc injectors, a reflashed EPROM, a Z32 MAF, and a SAFC. After that, all that is really left is a G/T28/R in some flavor.
