Its a 1995 s14
#1: Ok, so now I found out I'm missing the position switches on my transmission. I can get these from Nissan correct? Problem is I can't seem to find the part numbers for what I need. I need a OD (5th) position switch, a neutral position switch, and a reverse lamp switch. Courtesy Nissan has two part numbers for two seperate reverse switches, I can't tell if one is suppose to be the OD (5th) position sensor or not.
http://www.courtesyparts.com/2....html
Look at 32005 and 32005+A. 32006M is my neutral position sensor. So that means 32005+A is my OD position switch and 32005 is my reverse-lamp switch, correct? The problem is both are labelled as reverse position switches.
#2: How do I connect these to my inhibitor switch? Do I need to buy some sort of wire plus a plug that will connect to the position switches that I'm looking for? Or will this wire already be running into my auto transmission and I just plug it into these switches. As you can see i'm a newb at this stuff and still learning lol
Modified by Dazzla at 9:14 AM 8/22/2009
