DOHCbumper question
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
I'm quite certain this has been asked probably a million times. However I can't seem to find it in search.
I know you can get a dohc bumper to fit on a sohc, but what -- if anything needs to be done to make it fit?
Fergus
Car: '01 C5 Coupe
the screws. taking off the old one helps too
gniknave
It sounds like you're saying it's a direct fit? I've heard that it was a direct fit, and I've also heard there was a few differences (heard this from a Nissan wrecking yard). Just trying to figure out which one so I don't run into any frustrating surprises.
gniknave
el-bump-o
Can anyone confirm for me...DOHC direct fit on SOHC?
boost_creep
Car: 92 sr powered coupe,06 Spec V
direct fit.but doesnt look perfect.the 91-94 bumper is a tad wider and sits a bit lower.there is a molded trim piece that goes on the bottom of the fenders to make the bumper sit flush with fenders.
tr0ublemaker909
hes right they are the same thing just the fenders have a lil trim piece added on to both sides to make it flush with the wider bumper, it won't look good if you dont have those, and if you go to dealer it would be i believe 100 bucks a piece for each trim piece i suggest junkyard searchin
