DOHC wiring harness questions.... doing a swap and the harness i have is cut up.
zerepdivad
Car: '90 240sx . '02 Lexus IS300
Ok i bought the swap from someone in madison, that had previously swapped it into their 90 s13 and then sold it to me with trans, ecu, and wiring harness. I just noticed that theres a few things chopped up in the harness and i was wondering if it had been done for a reason or if they just were sloppy about pulling it out......heres the pics...... thanks in advance to all who reply.....
zerepdivad
bump anyone with any ideas or at least a wiring diagram of the entire harness so i can just manually trace everything myself?
na3j nitsuj
Car: 1990 S13HB KA DOHC
try taking out the back thing thats covering the wires...and try to locate the other end...or i think ur missing another connector...
i would have to check on my extra harness...i'll get back to u wen i get a chance..
zerepdivad
na3j nitsuj wrote:try taking out the back thing thats covering the wires...and try to locate the other end...or i think ur missing another connector...
cool thanks
zerepdivad
ok well it seems i got it all figured out and already arranged to get what was chopped off. thanks for the replies.
S13DrIfTmEkAnIcS
Car: 89 240sx
wow u got screwed if u paid for that....my dual cam harness has soo much more to it. but if your going to put the missing peices together be careful. they all need to be saultered and heat shrunk. some of those wires could be for sensors that have almost no voltage running through them, splicing wrong could eliminate it and screw ur day up. i have experience screwing up a harness. id just go get a good one
zerepdivad
S13DrIfTmEkAnIcS wrote:wow u got screwed if u paid for that....my dual cam harness has soo much more to it. but if your going to put the missing peices together be careful. they all need to be saultered and heat shrunk. some of those wires could be for sensors that have almost no voltage running through them, splicing wrong could eliminate it and screw ur day up. i have experience screwing up a harness. id just go get a good one
I found what everything is already there is actually about 3 or 4 sensors gone. The problem is fixed and i arranged to get everything already.
