DOHC TO SOHC distributor same??
mackdaddy240
Car: High performance with a clean look.
Im swapping my 90 sohc for a 92 dohc and running high compression. I have pretty much everything for the swap but Im not sure if the distributor from my 90 will work with a 92. Does anybody know if they are interchangeable?? same firing order?:confused:
_/_/_/M aurice
Car: Drifting, women, cars - not necissarily in that order
Firing order matters not. The SOHC has a different coil set-up than DOHC, therefore you need a DOHC distributor.
