dohc to dohc
kamikazestorm420
i have a 1991 240sx and i am thinkin bout replacing it with the s14 dohc.
i kno you need the intake manifolds or w/e to make it obd 1 but my question is do i need the s14 transmission or can i use my s13 one?
do i also need the s14 ecu?
WDRacing
unno about the ecu, but the transmission is the same.
Aaron_9349
Car: 95 240sx
are you using the same cams from the 91 or s14 cams?
kamikazestorm420
WD- so if my transmission is in good condition i dont have to bother finding the transmission?
i dont know yet .. im thinkin bout putting the 91 cams because i heard theyre better than the newer dohcs.
does that make a difference in if i need the s14 ecu or not?
WDRacing
Your current transmission will work fine and the S13 cams are way better then the S14 cams, they also work with no ECU swap.
Charlie240sxt
Car: 95 240sx SE Ka24det!!! 98 audi A4
just use the s14 block and head use your intake and header and your s13 ECU the transmission as WD said are the same also swap your s13 cams in
kamikazestorm420
thanks
