Dohc Swap Wont Start
Vernal
Car: (RIP) 1990 Hatchback 1989 Hatchback
Problem below...
Modified by Vernal at 11:11 PM 7/31/2007
MaximA32
Bad starter. Replace and you'll be fine.
Vernal
Problem below...
Vernal
Well I found out the problem. The engine I bought from this idiot is the problem. I can't even turn the crank pulley by hand or with a crescent wrench. So my starter keeps clicking because it can't even turn the crank. Has anybody had this problem or any ideas to fix it? Im pretty damn sure I have to pull it out and rip it apart to see what the problem is, but any ideas or experiences will help.
LayNLow240
Car: 92 240 coupe
take out all of the spark plugs and see if you can turn it over. cyls might be filled with water or other liquid.
Vernal
LayNLow240 wrote:take out all of the spark plugs and see if you can turn it over. cyls might be filled with water or other liquid.
I think the problem is with the transmission. Even in Neutral I cant turn the driveshaft. Something is getting hung up in there preventing it from moving. Could it be a misaligned clutch? And I am having trouble bleeding the clutch. I removed the clutch damper and turned the line into the soft one that goes to the slave and I loosen the bleeder and pump the clutch but no fluid leaves the master cylinder.
Vernal
Well I can push the car so I guess the engine/Transmission isnt locked up. I had trouble bleeding the clutch, I kept pumping and nothing. With a little trial and error I figured out it was a bad master. Replaced that and the clutch is bled now. I also figured out the electrical problem, but my starter is still just clicking. I dont have the belts on or the spark plugs in. What could it be?
