OK... today was a big day... so we take out all plugs and we were going to check compression on each cylinder. We put in the tester in the first plug hole and turn her over. SQUIRT!!! SQUIRT!!! there is gasoline EVERYWHERE! it is shooting out cylinder number 2 and about 10 feet up into the air...
We stop all testing and look into the cylinder and gas is being POURED into cylinder 2 from a stuck injector. My friend got covered in gasoline and we all laughed about it and had a gasoline fight afterward. We stop all flow to that cylinder and check compression again.
Cyl 1 160Cyl 2 155? can't rememberCyl 3 170Cyl 4 162
Supposedly this is with a 'leaky' tester so my actual compression should be a little higher, but that's pretty good for a newly rebuilt motor, right?
ok so we swap out the entire fuel rail with another spare we have lying around and it works. It works good. she now can IDLE!! A simple twist of the idle screw and she stays on.
so we try to rev her up and she bogs down somewhere around 2K? I don't know I don't have a DOHC tach yet... anything over 2K and she will bog bog bog. if you rev her a little she can get over it but she usually doesn't want to get over that 2500 mark. I know it's not the MAF because we have one that I KNOW works.
After playing a while with her she starts smoking... We think nothing of it as it is a newly rebuilt motor. We are trying to figure out why she's smoking and we find out that cylinder 4 isn't firing for some reason. A couple "light" taps with the back end of a screw driver and she works again!!! Hello 4th cylinder. It's good to see you again.
Even though we are now working with four cylinders we still can't seem to get over the bog after about 2500 RPM unless we keep reving till she slowly works past it. AND to make matters worse she's smoking big now... Big billowing white smoke....
We have no idea why she's doing it but the temp sensor says she's running hot, real hot. I read on this Wikipedia source that if you don't change out the DOHC temp sensor it will read high, so we didn't think much of it.
http://en.wikibooks.org/wiki/N...A24DE
Wikibooks wrote:-the water temperature sensor from the SOHC engine needs to be used. for some reason the resistance is different. if you use the stock sensor from the DOHC engine, it will register on the gauge as being higher than with the SOHC unit.
But even though we thought this might be true we didn't want to chance it and we turned it off. We let it cool then turn it on again and filled the radiator with water. She was THIRSTY!! I'd say she was on her way to being dehydrated. She cooled considerably after that but the white smoke seems to still hang around and we can't figure out the ~2500RPM bog yet. Also there seems to be some rattling coming from the timing cover... A brand new timing kit was used to replace the old one so I don't know about this.
So my main question for you's guys is what could be the bogging throttle problem and what is making all that white smoke? I can't think of a reason for there to be white smoke other than bad rings and we JUST checked compression... I think this has to do with it being overheated, because it didn't happen before that. HELP ME please
Thanks
