DirtyD »
https://forums.nicoclub.com/dirtyd-u119082.html
Sat Apr 18, 2009 2:02 pm
I am swapping a dohc motor into a sohc chassis, and have ran into a problem. I cannot find a how to or any info on this one. It is a plug that is located near or underneath the relay/fuse box on the passenger wheel well. It has a four connector plug and the dohc lower engine harness has a two connector plug. Anyone else run into the problem and how did you work around it?
