not trying to steal the guys thread..but i was wondering if your the ngk guy to go too..how much would ngk spark plug wires run me...for my 93 240sx se coupe?...elwesso wrote:I wouldnt see how this would give you anything but negative results...
If you suck out your PS fluid you are basically gonna make it so you can never have PS again without a complete overhaul..... The PS pump will die, hoses will crack, and the rack will dry rot..... Part of what keeps the system running right is the fluid, which keeps everything moist and pliable... Thats assuming you leave it out for a long time....
IF you run with no fliud, the pump is gonna make this GOD AWEFUL screech all the time.....
I suppose you could fill up the pump wiht fluid and cross over the hoses so its just circulating that little bit of fluid...
jeansguy wrote:Zing,
That is what I first though, but it requires pulling the fan off, the radiator out (for clearance), the alternator belt off and the crank pulley off.
It seems like the best solution, because if I like the feel of no power steering than I will just remove the pump, purge the excess fluid and cap the lines..........but it's just so much work. I was looking for the easy way out!!
