Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Fri Apr 21, 2006 10:41 pm
Wow, that's less than a 1G DSM Turbo! You could probably pull wicked boost, but what's the point? You won't find a turbo properly sized to make it worth it. The problem will be that for you to reap the rewards of such a low static compression, you will need a pretty small turbo. With this you will need to increase the boost of the turbo to make up for lack of flow. You could use a larger turbo at the 8.5-9:1 and run a little less boost and make significantly more power. Although, it was a nice thought, it really would be a waste of time and money.
