dohc or sohc
S13_405
Car: '89 Nissan 240SX coupe S13
I keep hearing that the 89' 240sx has a SOHC instead of a DOHC is that true because I was thinking of later putting in a CA18DET or a SR20DET an I also heard that if the engine is a DOHC the installation will be easier.
dabum
any 1991+ 240sx is dohcany earlier models are sohc
Touchdown038
Car: Computers, cars, sports
Yes.
Thee 240sx Owner
Car: Canadian 89 240 with LSD/stock no ac/ and 4 motor swaps
and yes if you have a DOHC... the SR swaps are alot easier to install due to the KA24DE wiring harness having most of the sensors as the SR does.
Altiman94
Car: 1989 Nissan 240SX
its not the sensors.. The dohc has the a/c and powersteering lines that you will need to run those accessories on the sr. It also has the gauge cluster you need for the guages to be operable. Same thing for the sohc and the ca swap. Trannies are the same on both the sohc and dohc, so the speed sensor and everything on the lower harness is the same
Thee 240sx Owner
one thing i didn't mention.. sorry..i'm a 240 with no a/c... damn canadians... but you did mention sensors as i justified up there :)
S13_405
Altiman94 wrote:its not the sensors.. The dohc has the a/c and powersteering lines that you will need to run those accessories on the sr. It also has the gauge cluster you need for the guages to be operable. Same thing for the sohc and the ca swap. Trannies are the same on both the sohc and dohc, so the speed sensor and everything on the lower harness is the same
Altiman94 so if you got a SOHC its easier to a CA18DET then a SR20
