mwknoerzer »
https://forums.nicoclub.com/mwknoerzer-u263185.html
Fri Dec 09, 2016 10:18 am
So recently I swapped my sohc out of my 1990 240sx due to a rod knock. After swapping I drove it around for the first day and the car would not warm up at all so I replaced the Thermostat and bled the coolant system again. The new thermostat I bought is supposed to open at 170 degrees. It warms up faster with the new thermostat but not a huge difference. So my problem is in the morning I can start my car and it takes around 20 mins to fully heat up, but while driving my temps will slightly drop to a 1/4 of the way of the stock cluster gauge or if I start driving before its fully warmed up it will never fully warm up unless i am stopped. I've driven around 15 miles and It would only warm up to a 1/4 of the way if that, but if I stop and let it idle it will go back to full temp. Is it possible I got another bad thermostat causing it to stay open, possibly air in the system? I know its not the gauge, that fully worked while I was sohc and the wiring is done correctly for dohc. Also when swapping to dohc I removed the AC is it possible that now that I don't have a thick AC condenser in front of my rad that maybe its getting too much air now and cooling it off while driving? Also its about 35-45 degrees out where I am not sure if that helps or not... Also my brother has the same exact set up as me but with AC and in an original dohc chassis and his warms up within 5-10 mins or within a lap or 2 around the block, I have to drive for a solid 30 mins or so before my temp gauge hits that very bottom dash of the gauge... My heat does work not the best but it does once its warmed up. Its gonna start getting really cold here and I'm trying to get this figured out. Thank you all in advance.
