DOHC KA MAF on SR
Blown240sx
Car: 1996 240sx
Ok ive heard over and over you cannot use the DOHC KA MAF on an SR, that you have to use the SR or KA SOHC. Well heres the question.
If this is true then why does my buddies SR (which we installed and wired in the MAF) run perfectly fine on a DOHC KA MAF?
da40
Car: 1995 SE 240sx
i run the stock ka dohc maf on my SR with no problems friend,i know alot of people that do too?????????????????????????????????????????
Warped
Car: 1993 240sx coupe - 2000 Audi S4 Stage 3
s13 sr or s14 sr ?
Nismo_Freak
Car: 89 Nissan 240SX
Title changed.
Warped
does anybody know the answer to this i would like to know too
AR31TU
They're about the same size. I have a DOHC KA and I happen to have an extra SOHC MAF. I compared the two while they were out and if memory serves me right, the DOHC is 4 pin and SOHC is 3 pin. The extra pin is for ground, so you don't need it. If you wired all of them up correctly there's no reason it shouldn't run fine.
wildacexxx
Car: 2002 Q45 nav sport
can u tell me how u wired up that maf? my maf just took a crap on me last nite
Warped
Does anyone really know the answer to this?i have 2 dohc mafs with pigtails and a sohc maf w/ no pigtail so if i could use the ka dohc maf that would be great
Blown240sx
Car: 1996 240sx
All we did was figure out which wire went with which and used the DOHC plug side off the KA Harness and the DOHC MAF.
Warped
blown240sx did you use the ka maf on a s13 sr or a s14 sr?
Blown240sx
Car: 1996 240sx
S14
Warped
well thats why it workedyou can use the s14 ka maf on a s14 and you can't on a s13
Blown240sx
Car: 1996 240sx
my motor is out of a S13
wildacexxx
he meant the engine when he asked s13 or s14. can u take a pic of how your wired it up real quick if its not problem?
BLKTOPS14SR
Car: 1998 Nissan 240SX SE Kouki
1971 Buick Skylark 455Buick big block
1970 Cutlass Holiday Coupe
2002 Ford F-150 XLT
1972 Chevy Cheyenne
I'm really interested if this works as well. It'll save me some $$$$. I have a S14 car and S13 Sr. Would the DOHC Maf work??
Blown240sx
Car: 1996 240sx
Ill get a pic as soon as I can. At the moment we are moving the motor to my new car. The harness I have was out of S14 using a DOHC MAF on a S13 SR20DET.
I didnt think it would work but we wired it up and it worked fine... So Im just as confused as all of you.
bardabe
Car: Z32
Alright I am really lost here. what are you saying? please clarify? from ym understanding did you put an S13 DOHC MAF into S14 SR? or what explain
what model DOHC MAF idd you put on what model SR I am extremly lost.
ex. (S13 DOHC MAF into S14 SR)
pics would be apreciated as well.
-Juantons
Warped
ok so we got its a s13 motorFor the maf- s13 dohc maf or s14 dohc maf?guessing a s14 because of the harness in use.
BLKTOPS14SR
2002 Ford F-150 XLT
1972 Chevy Cheyenne
So, a S14 KA DOHC maf will work properly on a S13 Redtop without problems?! If so I'll be able to start my swap alot sooner!! Thanks
bardabe
Car: Z32
Warped wrote:ok so we got its a s13 motorFor the maf- s13 dohc maf or s14 dohc maf?guessing a s14 because of the harness in use.
so I can't Use the 98 DOHC KA MAF because it has a diferent plug. what about if I solder the new plug on will it work?
Blown240sx
Car: 1996 240sx
Ill have pics up today cause we are pulling my motor to prep it so Ill have the harness with me.
Clarify for you all.Harness is the S13 SR harness modded to fit the S14 chassyMotor is a S13 RedtopMAF is a DOHC S14 MAF
I was looking at it yesterday and only 3 of the 4 prongs are used and I pulled back the wire covering to see if I could see what wires they connected to and they seem to be the same color on the harness side as they are ont he plug side... Ill do some more investigating.
Pics will be up tonight.
Warped
thankyou for your reply
BLKTOPS14SR
2002 Ford F-150 XLT
1972 Chevy Cheyenne
Yeah, I looked at my S13 harness and at my S14 harness and the wires are-white, black and black/white. The S13 has three and so does the S14. They looked to be in the same pin location as well. Otherthan the plugs themselves being different it should work. Thanks again.
Blown240sx
Car: 1996 240sx
thats what I found on my harness so I figured the wires were the same. On my harness we just cut the 4th plug wire off short and tapped it up.
BLKTOPS14SR
2002 Ford F-150 XLT
1972 Chevy Cheyenne
And everything worked fine?!
Blown240sx
Car: 1996 240sx
Yea we had the harness on a car for several months and not a single problem.
