DOHC CLUSTER WONT WORK.
eric7216
Car: 1990 nissan 240sx se
I did a ka24de swap and i switched out the tac from my sohc to the dohc but its not working, The oil light and engine light and seatbelt like tec. all work but none of the needles move not even the fuel gauge. Help i know i did the ecu wiring correct but ehat could it be?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Check your fuses. Your not getting power to the cluster. Its the bottom right fuse labeled gauges. If its good than check power at the fuse. If you have no power than look at my write up " how to fix s13 gauge cluster wiring" its the green wire....always the green wire! Lol.
eric7216
compactfean wrote:Check your fuses. Your not getting power to the cluster. Its the bottom right fuse labeled gauges. If its good than check power at the fuse. If you have no power than look at my write up " how to fix s13 gauge cluster wiring" its the green wire....always the green wire! Lol.
Where exactly is the fuse located i looked under the dash driver side didnt see any labled gauges
ShouldaHadaV8
Car: 92 hatchback 240sx, j30 diff, TIEN tie-rods
compactfean wrote:Check your fuses. Your not getting power to the cluster. look at my write up " how to fix s13 gauge cluster wiring" its the green wire....always the green wire! Lol.
do this ^ he knows his shiz, just take out the cluster and use a voltmeter to test for power.
compactfean
daily
Fuse panel. You need is right by your left foot when your sitting in your car.
eric7216
ALright so i messed around with it and the fuel works fine now. the backlights also. I havnt tried the speedo yet so not worries about that but the rpms are still not working. and all the fuses are working. You think if i replaced the rpm gauge with the gauge from the soch cluster that it would work?
compactfean
daily
Which harness are you using, sohc or dohc? Ecu? The reason I ask is because you can use either cluster .....its just a difference. In ecu's and wiring....I can guide you through either setup.
