Well actually he gets to do the hard part again. Hopefully he will rehabilitate the engine while it is out of the car so it will last longer.IWannaS15 wrote:I'm sure it was fun while it lasted. Youve done the hard part already, so I assume youre gonna drop another VH in there.
There is a voice from the distant past!sultan wrote:180hp is more than my q45 dyno'd of course it was 100 degrees out and car was (still is) throwing the knock sensor code. bad ks really pull timing bad
Thats the million dollar statement right there... VH's do NOT hold up to abuse that is for sure (and witnessed first hand by me)autoworkz wrote:we pulled the beast from a junkyard. pulled the heads off and cleaned the sludge out. they were pretty bad.
When I recently took Lola to the DynoJet, she pulled a 244 RWHP peak. This was with 103 degree air sucking into the air filter. The room was about 85 degrees.sultan wrote:180hp is more than my q45 dyno'd of course it was 100 degrees out and car was (still is) throwing the knock sensor code. bad ks really pull timing bad
I was thinking that this particular dyno was actually reading a bit low. I believe the car should be around 260 RWHP with the NICO ECU, exhaust, and intake that is on it. That is, utilizing a 17% driveline loss for the transmission and independen rear suspension. That doesn't even take into consideration the NICO stickers that are on the car (everybody knows that NICO stickers add 20 to 30 HP each )autoworkz wrote:so actually around 207 - 219 hp. Dynojets read 10-15% high
it`s hard to compair lower end dynos like dynojet or any other enertia dyno. our dyno dynamics dyno takes intake air temp, temp, humidity and barometric pressure into account when making runs or tuning, that way each time you run on our dyno, your numbers will be consistant. also, it doesn`t use big weighted drums as "rolling resistance" it uses a infinatatly variable "eddy current brake" to make resistance. DD dynos don`t have the "user error" factor. this is evidant by the "shoot out mode" dyno dynamics has a shoot out compitition, held at different shops, around the word, on their dynos in shoot out mode. they can only do this due to the accuracy of the dyno and correction factor for the weather.Jeff Williams wrote:It is hard to compare any individual chassis dyno with another one. That is kind of like comparing any single car with another of the same make and model.
What kind of dyno are you using for the 450SX?
Pull the E brake, hit the gas, and find out!slipperypanda09 wrote:um... noobed out question, is i30t fr or ff?
FFslipperypanda09 wrote:um... noobed out question, is i30t fr or ff?
