Dogred's pic
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
dogred
Car: 1983 D720
Here is a pic with my new rims. Need to get a close up of the new rims.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
I like your badge.
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Yeah man, did not notice it at first. bought it with the truck or had it made.
dogred
Car: 1983 D720
Original badges, on the grill and qauter panels. This truck has been unmolested except for the cancer and dirt. I found it on craiglist for $350 with starting problems. The transmission dust cover was countersinking the starter. Hammered it flat added a new battery, starter and flywheel. Hammered the distributor plate flat and cured a nasty oil leak. One more small leak to fix on the passenger side. passenger side close up of rim
I got some carbon matallic painted rims of the same style for sale if you are in the western wa area.
Modified by dogred at 11:22 PM 7/27/2009
lrayvick
Car: Datsun 521
The wheels look like Jackman's - made in El Cajon in the 70s? I have a set on my 521. Good job getting the problems ironed out.
breadbox
89 Koop
84 720 4x4KC
Awesome, you have the same rear bumper as me. I love that thing. I was going to clean mine up and repaint it but then I decided it looks better busted as s*** and lopsided.
dogred
Car: 1983 D720
I am wanting to lower my truck and was wondering if (anyone who has their truck already lowered) has part numbers for shorter shocks for the front and rear. I measured the stock monroe replacements today at work and the fronts are 12 1/2 in, and the rears are 14 1/4 in.
I am guessing that I want a 3" drop that I would want replacement shocks 3'' shorter?
PEZi
shocks depend on the method of lowering... in the front if you're just using the torsion bars you don't need new ones... but if you you spindles and blocks you'll just need to search for 'drop shocks'... they come labeled
for example... you search for the drop shocks for a 720... then choose the drop you have ie: a 2" block in the rear will need a 2" drop shock or a 3" spindle in the front needs a 3" drop shock
dogred
Car: 1983 D720
Repainted my grill.
Modified by dogred at 9:01 PM 8/2/2009
PEZi
haha... i just took out my highbeams as well
dogred
Car: 1983 D720
Tightened down the torso bar bolts and added a cat delete, bumper delete, new muffler and tip.
jdamion
Car: 1980 Datsun Pickup
your truck is something we all wish ours resembled. nice man
jdamion
how much play is on your steering wheel?
turbojunker
Car: 79 510, 81 720, 72 510-RIP
PEZi720 wrote:shocks depend on the method of lowering... in the front if you're just using the torsion bars you don't need new ones... but if you you spindles and blocks you'll just need to search for 'drop shocks'... they come labeled
Isn't that backward? Loosening the torsion bars removes travel, so you'd need shorter shocks. Spindles move the wheel uo in relation to the lower control arm without reducing the travel.
dogred
Car: 1983 D720
jdamion wrote:your truck is something we all wish ours resembled. nice man
Well thanks man.There is about an 10th of a turn of play, not to much.
dogred
Car: 1983 D720
Old pics of my ghetto ram air intake.
breadbox
89 Koop
84 720 4x4KC
there are easier ways to get air there. But the grill looks great.
I still want those badges when my truck runs I am gonna be on the hunt for a set of those.
dogred
Car: 1983 D720
breadbox wrote:there are easier ways to get air there. But the grill looks great.
If you have a better idea please share. That was the simpliest idea I could come up with. I do not want to get air from any lower, lots of rain and unsusoecting puddles around here.
PEZi
sorta... all i know is that both the blocks and spindles call for a drop shock
bracktheron720
Car: 1984 720 with 1980 datsun front end,1972 yamaha cs3
hey dogred im over on the other side of the state but im back and forth alot you still got the wheels for sale??iv got the same style as Pezi but too wide if you still have let me know whats up!!my truck had a big square cut in the hood when i got it so i slapped a little scoop over it and made a box that i stuck on the end of the air cleaner lined it up with hole and bam ram air baby!!
dogred
Car: 1983 D720
Take your pic carbon mettalic or black.
bracktheron720
how much you want for a set??????
turbojunker
PEZi720 wrote:sorta... all i know is that both the blocks and spindles call for a drop shock
Thing about the rear is the lower shock mount is on the U bolt plate, not the rear end housing, so a shorter shock is not necessary with blocks. A stiffer shock of the same length may help keep the axle from hitting the frame though.
dogred
Car: 1983 D720
bracktheron720 wrote:how much you want for a set??????
$60
bracktheron720
dang thats a good deal!!let me get my sh** together and well have to figure out a way to get together!!
PEZi
hmm... you make a good point
the only thing is that both call for them
i'm not running them though... KYB's all around did me well
dogred
Car: 1983 D720
bracktheron720 wrote:dang thats a good deal!!let me get my sh** together and well have to figure out a way to get together!!
I will need to know one week in advance so I can get time off from my busy schedule.
The carbon ones have been bead blasted and there is one can of primer and paint on each rim.
The black ones are painted over the original white, so they have higher resilance to scratches.
I could meet you in Tacoma, but I have not taken this truck on any long hauls since I have owned it.
flinterman2000
turbojunker wrote:Thing about the rear is the lower shock mount is on the U bolt plate, not the rear end housing, so a shorter shock is not necessary with blocks. A stiffer shock of the same length may help keep the axle from hitting the frame though.
The reason for the shorter shock is not to prevent the axle from hitting the frame. Its to prevent the shock from bottoming out and killing the shock. If the travel for the shock is longer the shock, the seal in the shock usually hits the bottom of the shock and damage the seal. Repeated hitting of the bottom will eventually burst or warp the seal and end up with a useless shock. A stiffer shock will only change the way the ride feels but it makes no difference to the travel. But then again this is for those who carry load in their trucks.
bracktheron720
yeah no problem dude my trucks pretty tore up rite now so it will b a while before i would b able to make it there but i will defenetly keep in touch!!
turbojunker
I understand that. But the lower shock mount is on the U bolt bracket, not the axle housing, so shock length is unaffected. When all you do is move the axle up in relation to the body, the shock travel has not changed. If anything, you get less travel unless you removed the bumpstops completely like I did.
Return to “Datsun 720”
