ECU is good, no codes. It's trying to crank but the injectors are not firing at all. What do you mean by turn the CAS? It only can bolt in one way.burntricer wrote:any ecu codes? is it trying to start like cranking and sputtering...? are your injctors not even firing or? a way to check is pull the rail, prime the pump and turn the CAS.... you will see if they are firing from there....
its something stupid and little, i once had a wasp get into my fuel rail when i was changing my injector o-rings...
So wait, if the ignitor chip is bad it will keep the injectors from firing? I thought it only controlled the plugs/coil packs.I will try the CAS then, otherwise I think it could be the pins on the ECU. I took a noid light set to the injector harness and they did not light up which leads me to believe the ECU pins for the injectors are bad. But I am wanting to try other options first, thanks guys.nzmoman wrote:The ignition is linked to all things that make the motor go starter, fuel pump, spark, and air sensor. If you have an issue in the ignition system everything else electrical will work, but the car will not turn over, and you will not get those dash lights. But you ALSO should not get any fuel pressure if its the ignition.
Also, are you sure your ignitor chip is okay? I have seen this kind of issue with bad or faulty ignitors
Oh, ok. Thanks a lot. I was just mainly seeing if starting fluid would help cause I wanted to make sure that everything else worked. And just on a side note, with the starting fluid, it would only rev up to about 3K which sounds like a MAF issue too...blacksrjdm wrote:If it started with starter fluid then you have a fuel issue. Without a doubt although, you dont like to listen to me, because i still think it has something to do with the ignotor chip. If the ignitor chip is bad then it shuts down different functions. Fuel delivery is one of them, and the main function of the ignitor chip. U said yourself that you have fuel at the rail but the injectors arent doing their job. CHANGE THE IGNITOR CHIP just like I did when I had the same problem, they are touchy and fail often.
