I just talked with the dealer and the master tech advised that it is normal for a new Z to rev between 1800 - 2100RPMs upon a cold start and then go to a lower idle after a few minutes.oc350z wrote:I bought an new 08 last week and had a Nismo cat back installed prior to delivery. It is doing the same thing your car is doing, 2000RPM upon a cold start and goes to normal idle within a couple of minutes.
I'll call the dealer to see what they say and advise further.
Sounds good, so why then did my new Z only do this shortly AFTER I installed the CAI around 1500 miles? When I bought the car with 7 miles on it until 1500 miles, the car started normally with rpms around 800, even when cold. My new Mustang did the same thing but only after installing a CAI and other mods.Q45tech wrote:By DESIGN cold cranked cars rev to light the precats and cats faster........trade off to reduce emissions faster............trade 1st 90secs for less over first 10 minutes.Function of coolant temperature..................solved by installing external coolant heater and keeping car in heated garage.
I guess for you only to be sure it's the CAI causing it would be to replace the oem intakes and cold start the motor. I'm not sure what the difference would be if any though, since when you installed your CAI you installed it with the OEM MAF sensor, and the connected the crankcase vac line to the intake piping... right?PerfectApex wrote: Sounds good, so why then did my new Z only do this shortly AFTER I installed the CAI around 1500 miles? When I bought the car with 7 miles on it until 1500 miles, the car started normally with rpms around 800, even when cold. My new Mustang did the same thing but only after installing a CAI and other mods.
Thats a good idea but a hassle. And yes to your question. I might call Stillen where I got the CAI and ask them about this but doubt I would get an honest answer. Sales 101. Thanks for your input on this.samej82 wrote:
I'm going to take it in on Monday to have them check the computer per his suggestion. He further advised that it would not be necessary to leave it overnight to replicate the issue since the computer settings will show if all is normal whether the engine is cold or hot.
I'll advise futher after they do the computer check.
I went to my dealer this AM where the tech checked the computer and all was normal. Not being a believer, I asked if we could start a couple of 08 6 speed Z's that were cold. I started two myself and they both reved to 2k for a minute or so before they went to normal idle as mine does.
The tech further advised that the fast idle control is at the cats and a cat back exhaust would have no effect.
Maybe...... the reason it didn't do it until now on your car could be related to colder weather in your area causing it to go to fast idle upon start up. By the way, new Mustang GT's do the same thing at cold start as do Corvettes, the two other cars I checked out before I bought the Z.
Enjoy your car.
