You do realize that the G35s use throttle by wire right? The only resistance to pedal movement you will feel is the spring that the pedal is attached to. And its a fairly light spring at that. Unless you're trying to push the gas pedal through the floor...Jacko3 wrote:I have never had to push a gas pedal so hard before in my life to get to 5K RPM---thats how much torque there is in the revised engine. Till date, I have been unable to floor the whole pedal to the metal even at 1** miles per hour. That's how I know, there is still some left over power in that VQ engine. Really fantastic engine! I love it!
You think it modifies the intake/exhaust valve "height" around that RPM range and I'm feeling it?RED_DET wrote:CVVTC... Continuously Variable Valve Timing Control.
It sounds like you might have an issue like some people who play video games do. They end up pressing the buttons or thumbsticks harder to try and do whatever it is they are tying to do faster than the game controller will allow. It is pointless. I don't have any hard suggestions to fix this. Just try and relax a bit.Jacko3 wrote:C-Kwik:
So, what do you think would account for this? Since after installing the mods, its gotten a lot better and freer to press that pedal.
You said, "Unless you're trying to push the gas pedal through the floor...". C-Kwik, as you well know, I haven't yet learnt how to drive like a normal person. I always try so hard to press the pedal to the floor and probabaly through it, in any car I get into. Maybe this is a serious problem I have and I don't realize it. I was warned by the sales consultant not to flog the FX 50 I went to test drive---he actually threatened to drive the car back to the dealership if I flogged it one more time.
Hard to say what it is. I mean, if the torque curve prior to this surge is in line with other G's then you might have gotten lucky and have some set of conditions that is providing you with a bit of extra power. Or if the torque curve after the surge is in line with other G's, then you might have a problem.Sentientbydesign wrote:Guys,
NO THREAD JACKING ON THIS ONE!!!
It feels similar to when I drove a WRX and the turbo started to spool.
That generally provides a broader torque curve, but generally wou;dn't account for big surge. Of course its hard to quantify how big this surge is...RED_DET wrote:CVVTC... Continuously Variable Valve Timing Control.
C-Kwik, I am working on it. I know I will get there someday. The G is a beast that possesses every fibre of my person.C-Kwik wrote:
Thanks for the explanation, but this is all info I know...not to be applicable to this situation.kdfja1 wrote:Becuase your engine is a Rev-up engine i'm assuming, along with your spacer you will feel a "kick" wen you hit high rpms. What the mechanics behind it is, the new plenum for the Rev-up model has more capacity for air so when you hit higher than 4k rpm it will suck in alot of air to keep up with the excessive combustion of your engine. This is only enhanced by your Plenum spacer which also creates a higher chamber for more air in your plenum.
Btw, you are not feeling "torque" when you feel the kick it is actually an increased HP that you are feeling. Notice in the 03-04 models the g35C has more torque but less HP, the Rev-up models have LESS torque but MORE HP, and the name "REV-UP" is quiet self explanatory (REVING higher to get more POWER or horse power). If you want both positive sides of the coin purchase a MREV2 which is basically a 03-04 lower plenum that will make up for the torque lost in the newer "Rev-up" models.
Hope this explanation helps and true
LOL. Don't tempt me man! I do miss it though. But more than anything, I just miss getting out on the race track. Been thinking about picking up an old Datsun project to beat up on. Of course, that could end up being a big expense all said and done.Sentientbydesign wrote:I know you miss your G, come drive mine!!!
The move to a large plenum box likely has a lot more to do with evening out airflow between cylinders. Tha large volume will really provide more potential for higher flow to the cylinders for an very short period when you change throttle position quickly. But once it stabalizes, the airlfow will still be limited to its weakest link.kdfja1 wrote:Becuase your engine is a Rev-up engine i'm assuming, along with your spacer you will feel a "kick" wen you hit high rpms. What the mechanics behind it is, the new plenum for the Rev-up model has more capacity for air so when you hit higher than 4k rpm it will suck in alot of air to keep up with the excessive combustion of your engine. This is only enhanced by your Plenum spacer which also creates a higher chamber for more air in your plenum.
Actually, you don't feel HP. HP is a calculated figure that takes into account torque and RPM. If you had a motor that produced a constant amount of torque, in a given gear, the car would accelerate at the same rate from idle to redline. But if you looked at the dyno chart for that motor, the HP curve would be a straight line that slopes up. The HP curve would not have a direct relationship to acceleration as it would imply that acceleration force would be twice as high at redline than it is at half of redline. But that wouldn't be true. And if you increase torque at any given RPM, the HP at that RPM will also go up.kdfja1 wrote:Btw, you are not feeling "torque" when you feel the kick it is actually an increased HP that you are feeling.
The peak torque on the rev-up model is lower, but what you aren't considering is that peak torque does not necessarily dictate that there is a loss of torque at all other RPMs. In fact, if you calculate the torque at the peak HP RPMs then you'll realize that at these RPM's the rev-up has more torque. Further, if you were to plot the torque peaks and the torque values at the HP peaks, you'ld find the rev-up motor has a flatter curve between the torque peak and HP peak. It's also likely the trail-off beyond the peak HP RPM would have similar traits as well and may have even more torque at redline than the non-rev-up does at its redline.kdfja1 wrote:Notice in the 03-04 models the g35C has more torque but less HP, the Rev-up models have LESS torque but MORE HP, and the name "REV-UP" is quiet self explanatory (REVING higher to get more POWER or horse power). If you want both positive sides of the coin purchase a MREV2 which is basically a 03-04 lower plenum that will make up for the torque lost in the newer "Rev-up" models.
Just think...your MPG could have been even worse without the mods and WITH the EthanolJacko3 wrote:All the mods helped with MPG until they decided to blend ethanol with the gasoline.
