Yea i kno a coil or injector would be be the cause of a mis..but im not really concerned abou tthat right now im concerned about the noise. And who gaf about spelling are you my teacher or somethin is it that serious?? i dont think im gonna get graded on making a postt. anywayy..any ideas?goody94q45 wrote:If you have a miss you should pull the ECU codes. It's sounding like a coil issue.
When i took it to the shop the guy pulled up the codes..he said cats and a misfire came up.paranoidjack wrote:Intermittent CEL's can often be an o2 sensor. Have you scanned the code(s)?
I kno cats dont cause a misfire..u asked what codes came up and i said the cats, and a misfire. I never said the cats caused it..but yeaaa..i was thinkin the valve is gettin stuckk and causing it to misfire as well. Im not too sure what cylinder is misfiring, the mechanic and I do business together i sell parts to his shop, i can kinda tell he didnt want to be bothered with it at the time..but im goin to look into it more. He told me it wasnt a lifter but im def thinking it is..thanks for the help anymore would be good too.goody94q45 wrote:Cats don't cause a misfire, bad coils do. Which cylinder was the misfire in? Did he give you the code #'s.
I'm thinking that a misfiring cylinder may cause valve or HLA rattle?
