Cyberkreig wrote:buddy of mine was telling me that i probably wont be happy with VLSD. Says that for burnouts or HARD acceleration you will still only power one tire and leave one tread mark?
Here lies the issue...
You have to have wheel spin for the VLSD to lock up in a straight line, cornering naturally thickens the outer wheel's fluid. The spinning plates cause the fluid to heat up and thicken which makes the diff have it's limited slip effect.
A clutch type is torque reactive. Meaning as soon as you apply torque it will be in a limited slip mode. Therefor it 2 wheels the whole time you have any torque applied to it. It also is designed to force the clutches together even harder when you apply more torque.
