Qgrappler »
https://forums.nicoclub.com/qgrappler-u270.html
Tue Jul 08, 2003 11:52 am
Re compressor
Yes, got it from Harbor Freight--dont hold your breath while waiting for it to arrive. It was a little tricky to get into the coils, but by the time I did spring number 3 I was pretty good at it.
Watch carefully how you put it together. One of the holes through which the bolt passes is threaded and the other is smooth. THe end of the bolt has two large nuts which lock against each other. I looked at it for a while before I got it together the way they showed it in the diagram, ...which was not intuitive. It goes together the wrong way perfectly well. Put a little grease on the treads, as suggested, and I agree, dont use an airtool. It wasnt that hard to turn with a regular socket ratchet.
Re Tylenol. Q45 tech is absolutely right. you just cannot gobble this stuff.
ALSO, note regarding kids tylenol, which everyone uses now instead of aspirin....the instructions are very hard to interpret, in my opinion. They give you a chart which relates weight to the number of teaspoons you are to take, but since it comes with the little cup on top, I think many people believe that the number is how many of little cups they should give the kid.--WRONG-- If you do that, you'll be overdosing your kid by 2-3 times. ( the smaller he is, the bigger the overdose will be in this mistake. I have read that the number one cause of liver damage in kids is from acetominophen (active ingredient in tylenol) overdoses. Sorry to continue off topic, but I think this stuff is worth the caution)
