does this sound possible?
D1 guy
Car: 1997 kouki S14 SR powered w/400whp and a stock 1994 FD R2 (26,000miles),
S14 SR20detTurbo: GT2871R Nismo Yellow Top 555cc Injectors (Flow at 615cc) Divorce PipeBlitz LM intercoolerWalbro 255 fuel pumpBlitz Down PipeTomei Adjustable Fuel Pressure Reg.Apexi GT Spec Cat-Back Exhaust HKS 256 & 264 cams GReddy Type RS Blow Off ValveFidanza Light Weight FlywheelGReddy Profec E01Spec 380 ft/lbs torque clutchJWT Tuned ECU (615cc injectors and Z32 MAFS)Z32 Mass Air Flow SensorApexi Intake Filter
Is 400hp possible at 20psi or under? 400hp is my goal for this car. I can run 110 octane in it. Any ideas would be great.
sr240dett3
Car: 92 S13 + RB25 + Silvia Front
stock manifold?
I would recommend getting a new exhaust manifoldThe stock manifold will not Flow enough airThe VE will be a lot nicer if u get a better manifold
Sounds like your serious.. I would recommend a serious manifold
I don’t see why not, but if not, it will be near your 400 mark.Only one way to find out. Put it all together and make some pulls
I just picked up a Peakboost manifold
I also am looking for 400hpAnd also have a GT2871R, i have the .82
S13 blacktop sr20detGT2871R .82AEM EMSGreddy intake manifoldPeakboost exhaust manifold/downpipesard 800cc injectorssard topmount fuel railsard FPRGarrett FMIC 30x12x3.5Tial 38mm wastegateGreddy Type RS BOVCometic headgasketARP headboltsWalbro 255lphZ32 MAFZ32 Fuel Filter
Ordering my Cams,. And gears this weekHKS Stegp2 264/272 (most likely, or both 272)
I better put down near 400HPOr ill be pissed,
I am waiting on a lot of the parts to come in.Once it’s all here I will post up pics.Then get her done, and post up some numbers
AJ1356
you should be able to acheive 400 horses with less than 20
sr240dett3
by the way good luck !!
D1 guy
Yeah I forgot to mention that I have the 300zx fuel filter and a 255 walbro. The under 20psi is a good thing since Im running my factory headgasket. Ill keep you guys posted b/c the car should be good to go in about 2 weeks.
AJ1356
good luck man, keep us updated
