does this sound like a bad heater core?
dubstyles240
engine operating temp is normal, thermostat IS good, and both heater hoses get pretty warm. The fan blows ice cold air though. sound like a clogged up heater core?
p00t
coolant could be low or the door that lets air through the heater core might not be opening
the heater core is nearly the highest point in the system so if your fluid is low it will not flow to it, jack up the front of the car to make the rad the highest spot, make sure the car is cool, start it and run it for a short while with the rad cap off, then stop and refill up to the top of the filler neck
s13sr20chris
you may want to reach under the dash and operate the air mix door manually.
