does this sound good for the money?
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
I have a chance to get this stuff for like $1700. I think it is a bit high, but what do you think? Garrett T3/T4 .48 AR Turbine .50 AR Compressor (I chose 57 Trim Stage III Wheel) by Turbonetics- tubular stainless steel manifold (had a machine shop make relief cuts on the mounting flange, in between each runner to allow for better thermal expansion)- 3" downpipe w/ o2 sensor bung (had an additional bung welded on for wideband 02, plus coated dp in turbo black thermal coating)- 38mm External Wastegate (came w/ 1 bar spring - big blue, also have 7.25 PSI spring - small green)- 2.25" Stainless Steel Intercooler Piping- intercooler w/ extruded Garrett Core 24" X 6" x 2.75"- FMU w/ 12:1 Disc- 38mm Recirculating BOV- Stainless Oil Feed, Return and Fittings- Air Intake Filter w/ Maf Adapter- Silicone Boots for IC piping
Modified by emperor_lunchbox at 1:54 PM 2/16/2006
chmercer
sounds like a bad deal to me
emperor_lunchbox
how much do you think it should cost. the guy said these parts have about 3000 miles on them
david200095367
Car: 91 fastback 93 coupe w/s14 sr20det 98 s14 kouki
hum seems to much if you ask me. i would only pay about 900 if they are used parts.
Iamjohnhayes
Car: 89 Single Cam Hatch
if he was using an fmu i think you should be asking him how long ago he blew up and what exactly failed so you can have a clue what still may be usable. i also sencond the fact that, that is too much for used parts.
crzycav86
Car: 93 Nissan 240SX KAT
Kinda on the high side. $1200 would be what I would pay.
emperor_lunchbox
cool. I will see if he wants to renegotiate. This kit is a boost designs kit that was adjusted to work properly.
Edub1
Car: 89 240sx KA-T
Most people here would agree that the KA requires a .63 A/R turbine side. The .48 will be too restrictive.
emperor_lunchbox
after hearing what you guys are saying I think I will just keep my ear to the ground unless the price gets really good. I was kinda settling if I bought this anyway. Its not the turbo I want, I dont want to recirculate my BOV. I don't really want to run an FMU, I would rather have a more robust fuel solution. Anyway, if anyone knows where I can get equivalent parts please let me know. Thanks.
Edub1
Car: 89 240sx KA-T
I have the turbo if you're interested. Check the FS T3/T04E thread for pictures.
Modified by Edub1 at 7:59 PM 2/16/2006
savatoge
Car: 95 240SX SE KA-T
Edub1 wrote:Most people here would agree that the KA requires a .63 A/R turbine side. The .48 will be too restrictive.
Not necessarily true. The .48 will spool faster, which is perhaps what some folks are after, ie. autoX, drifting, gymkhana. Plus, a comparitively larger A/R turbine can be detrimental when you're running a smaller boost setup anyway. In this case, it's better to get into the boost quicker and produce a broader, flatter torque curve. Also, the type of manifold used can have a much more pronounced effect on the performance differences between varying turbine A/R sizes.
Edub1 wrote:I have the turbo if you're interested. Check the FS T3/T04E thread for pictures.
You're recommending a specific turbine A/R...and then later, the turbo specs you recommend just happen to match the turbo you have for sale. Interesting.
Iamjohnhayes wrote:if he was using an fmu i think you should be asking him how long ago he blew up
People have been running FMUs for a long time now...longer than a lot of the people on this forum have been alive. It's true that you can blow a motor with an FMU. But you can blow a motor running an SAFC just as easily. For a low boost setup, ie 7 PSI max, where you don't have to worry about major timing adjustments, a properly sized FMU works very well. I've run an FMU and datalogged hours and hours of AFR, RPMS, boost, and injector duty to say that you can run an FMU just fine without risk of blowing a motor. It's not ideal for a track setup, but then again alot of people are only after a little boost for their daily driver and an FMU makes sense in this case.
