Does this sound Correct?? Compression woes..
SixSpeedSleuth
Car: Several
So, I go to the business where I got my motor to tell them what the compression was, and they tell me that a compression of 125 is normal for an SR20DET. From the countless pages of information I have gathered says differently. Somebody please tell me what the compression should be. My compression is 125,123,75, 128. Something is not right. Opinions?
virus77
Car: 95 S14, 71 240z, 97 e320
one cylinder usuall means broken rings or ring lands or a valve. My bet is on broken ring land. Drop some oil in the low cylinder and see if it raised the compression.
SixSpeedSleuth
Car: Several
Yeah, I did drop oil into that cylinder, and it did not change the compression. So, I'm not sure. Would a compression of 125 all the way across to low?
SixSpeedSleuth
Car: Several
Bump?
sil beer s13
Car: Kumori SPL S14
well
mine check out about 150ish
grey_240sx_man
Car: 1990 240sx coupe
125 would be the lowest. 159 is the the most optimal. 155 all the way across is what I run. still can't be 15 apart though and definately not 50 apart. Good Luck
virus77
if it didnt change compression then it could very well be your ring lands or a valve. My guess is still on ring lands. you can pretty much eliminate head gasket since the ones next to it are fine and its not your rings either.
