does this look bad? this looks bad....
projeks13
Car: 89' 240sx coupe
yea i'm thinkin this could suck....
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
damn that sucks and would check that out ASAP!!
Joe
huhlooks like an impact.
thats strange
pull it off ASAP. only a few bolts.
nizmo zilvia
Kamin wrote:huhlooks like an impact.
thats strange
Exactly what I was thinking
projeks13
can i take it off without having to take pulleys off i was snooping around and it looks like i'd have to take teh alternater pulley off. and with the clearance betwix the block and rad unless its easier than i thought i might have to drop the engine
Joe
what?just mark the cam angle sensor so you dont loose your timing
remove the 3 bolts on the CAS, then remove the smaller bolts holding on the upper cover. theres like 5 or so. really easy.
nizmo zilvia
wow... your making it look like more work for yourself then there really is. Do exactly what Kamin said.
projeks13
thanks <---------nooB
nizmo zilvia
How long has this been like this for? I doubt its been like that for a while otherwise it would of got in the way of your timing belt.
**** your online now. Why dont you just walk outside or w/e the car is and take that cover off and take care of the problem. Take pics too!
240z4u
Car: '95 Nissan 240SX
Not nearly as scary as the "look but don't touch" sticker you got with your last summit racing order!
Bluefire
Looks like the bolts broke and the spring in the cam gear slammed the came gear bolts and cover out. Theres probably going to oil all over the inside...
-Bluefire
node
Let us know what you found out. That is strange.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
That is for sure what happened. You can clearly see the four bolt marks from the cam gear cover. That is going to be a huge mess and I'd plan on buying a couple cans of degreaser and a bundle of shop towels while you're at it.
Have you noticed that your motor is low on oil?
Eikon
Car: 71 240z, 93 Supra TT
Did you just get this engine? Has it been installed and driven yet?
My guess is that projeks13 just got this motor shipped to him. I think something impacted the front of the engine in shipping. Look at the dent in the first picture between the upper and lower bolt marks. I think the motor impacted something and that forced the timing cover into the cam bolts.
Either way, you need to take the timing cover off.. it's not hard. Once you do you will know much more. If theres oil all over... see bluefires response.
You might be able to pound out the dents with a hammer... or just get a new cover.
If it was from an impact... You'll want to make sure the cam gear isn't damaged. I'm also not sure if the cam or valve train can be damaged by getting shoved to far into the head????
projeks13
eikon's got it right i'm thinkin the engine was impacted during shipping (it hasn't been started yet thank god) but yea i took a hammer and pounded out the cover so it looks like it'll fit now there wasn't any oil inside the cover so thats good.
