Does this clip about stance make sense?
pat93
http://www.youtube.com/watch?v=rk6zeAgka5g
i read his problem and saw the clip, buthonesty, i don't understand it and can't judge if what he trying to say is make sense or really isa problem.
Here is what he describe his clip"Stance Coilovers refuse to rotate at the ball joint in the camber plate. Instead they rotate the threaded body around the piston, causing many problems."
I beg coilovers veterans in here pls throw some 0.02dollar.
94_240sx
Car: 94_240SX
Okay, I hear exact same noise when I make turns. I think I'm having the same problem. Should I lube up the ball joint or something? It's pretty annoying.
E7-S14
Car: ess 14 foo!
i literally watched that video over and over trying to make an assumption of whats wrong..
what hes doing is twisting the coilover while moving it to side to side..he say that the threaded cylinder is rotating around the shock(which it looks like it is) and not at the ball joint
i think he assumes that the coilover is supposed to spin at the ball joint.. which it isnt..(i think)when he moves it it moves side to side just fine..
my solution would be to lube the ball joint..(this conclusion is from limited experience and logic.)
94_240sx
Car: 94_240SX
One drop of WD-40 on pillow ball joint fixed the problem. Noise is completely gone now.
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
E7-S14 wrote:what hes doing is twisting the coilover while moving it to side to side..he say that the threaded cylinder is rotating around the shock(which it looks like it is) and not at the ball joint
Technically the coilover is supposed to spin at the ball joint, how else would it spin when you turn the wheel?
pat93
Finally, I've the source of this clip.I have been posted in zilvia.net. There are many stance users found the same problem. Seemingly, it turn to be a malfunction of camber platewhich is supposed to be full circle rather than 2/3 circle.
THis really cast doubt on the stance product.Should i still going to buy it or should i change my route tocusco zero-1 or greddy.
nieko
Car: 1989 Nissan 240sx
um i dont understand how that would have any affect on anything? if it was 2/3 of a circle or a full circle? someone care to explain? i just received mine and they have the 2/3 circle
seejaytoo
Car: 1993 240sx Hatch
i assume it would just be weaker, either way it seems like their machining specs are off, and a quality control issue as i figure qc would catch those things, or maybe thats how its sposed to be dunno i dont have stances, but it does seem odd
nieko
anyone have any other opions on this? or facts? im installing today i guess ill see if theyre working or not =\
AceInhole
seejaytoo wrote:i assume it would just be weaker, either way it seems like their machining specs are off, and a quality control issue as i figure qc would catch those things, or maybe thats how its sposed to be dunno i dont have stances, but it does seem odd
It has nothing to do with the design of the plate itself. It's more or less the distinguishing characteristic between plates that have a better spherical bearing vs ones that have a defective bearing (that does not rotate easily).
The strut should rotate at the upper mount. Rotating the strut body around the shaft itself promotes unnecessary wear on the piston and shaft seals.
94_240sx
Car: 94_240SX
I have something for you guys. I emailed Stance regarding this noise and they sent me a pair of new camber plate. Half moon shape one is new plate that they sent me. Flat area is supposed to face the motor. According to Stance, current ones that on my car are defective. Half moon one should have better bearing. Good thing that I haven't done alignment yet. I'll try to replace them this weekend.
Modified by 94_240sx at 11:20 AM 10/12/2007
nieko
oh ok good mine came with the new ones like that
pat93
I thought this thread is dead already.I am keeping my eyes on the thread at zilvia.net about the malfunction ofthose plates. Those people also get the new plates from stance as well.It's like 6 pages thread; I saw at least one guy trying so hard to fix this thing in every possible way until he gave up. This fact stop me from buying stance really. I wish I was in the time that Stance was so good as people in this forum praise them.
nieko
im pretty sure they fixed everything now in the new shipments. enjuku got a new container of them about 2 weeks ago. (thats where i ordered them from) so far so good? but then again not completely done adjusting everything and driving
94_240sx
Car: 94_240SX
nieko wrote:oh ok good mine came with the new ones like that
It's not about shape of the plate. It's about the ball bearing. If you got them recently, I'm positive you got the good ones.
m tr4nch
Car: RS13, Z31, P11
94_240sx wrote:If you got them recently, I'm positive you got the good ones.
wrong.. i got mine last week directly from stance and they have the messed up mounts check out my posts in the thread on zilvia.. its 9 pages now (mine are on pg 9)
94_240sx
Car: 94_240SX
Well, I know what you've been going through. Sorry about that. My new plates didn't work, so they shipped out another set yesterday. They took them out of coilovers from most recent batch and guaranteed that those plates are good.
m tr4nch
Car: RS13, Z31, P11
94_240sx wrote:Well, I know what you've been going through. Sorry about that. My new plates didn't work, so they shipped out another set yesterday. They took them out of coilovers from most recent batch and guaranteed that those plates are good.
yeah its retarted.. we'll see what happens though
nieko
so like... i think i did get the wrong plates lol so what do you do to get new ones? just call and say i got the wrong ones? and then thats it they ship new ones?
94_240sx
Car: 94_240SX
nieko wrote:so like... i think i did get the wrong plates lol so what do you do to get new ones? just call and say i got the wrong ones? and then thats it they ship new ones?
Call this number and they will ship out new plates right away.(847) 290-1568
Mine got fixed. When I turn steering wheel, I hear no noise and both nuts on the top mounts turn also.
nieko
do i have to ship the other plates back first? or will they ship them and then i just ike throw the old ones away or something? lol thanks for the number though im gunn call after school.
94_240sx
Car: 94_240SX
nieko wrote:do i have to ship the other plates back first? or will they ship them and then i just ike throw the old ones away or something? lol thanks for the number though im gunn call after school.
Don't worry about your old ones. They will send you a new set. Some batches had a problem, but I gotta give credit to their customer service. Overnight delivery was offered, but I chose Ground. Just call them and they will take care of you.
nieko
ok cool, im calling them at 2 2morrow so how long did it take u to get them ground shipping? just wondering lol
94_240sx
Car: 94_240SX
I got them in 3 days.
nieko
nice, i cant wait to have non glung glung noises and clunk clunks and all that stuff ahha
Justin VanWinkle
Car: '91 240sx FB(Looking for LS1)--- '92 240sx FB--- '93 240sx FB(DD)--- '04 RX-8--- '03 SV650(Track)
Yep, I just called Stance myself - the guy said they made one bad batch.
He said it doesn't harm performance, and it's not dangerous in any way at all...
He said new camber plates will show up at my house in approx. 1 week
You boys know what Quality Control is all about???
Bosrudorfer
Car: S14
... my KTS don't have this problem. Should have bought quality boys
nieko
you say stance isnt quality because they made a mistake? and they fix it instantly when you call them? hmm
AceInhole
nieko wrote:you say stance isnt quality because they made a mistake? and they fix it instantly when you call them? hmm
Good customer service helps to make up for a poor quality product, but does not necessarily replace it.
nieko
each opinon is your own but i personally like stance, i think they make a great product just a one flaw that is easily fixed if u call them so the good service kinda does make up for poor quality product
