cmkelly wrote:And from what I understand driving without a thermostat or one stuck open is not good for the engine. Engines are designed to run at a certain operating temperature and colder engines cause more damage than normal temp ones.
Warm = better
Yes, this is true. It also kills fuel mileage since the engine stays on a "choke-like" fuel map.On another note, often people will run no thermostat in a car they are selling to cover up a cooling problem.
Anyway, pretty much every car I have bought recently needed a thermostat, including the 92 240 I just bought. I just put one in yesterday for that matter. My car had the exact same symptoms as was originally mentioned. I am in TN, and normal temps for Jan are 50's/30's (h/l), but have been a little more this "winter". Regardless, even at 65 degrees last week my car would not warm up all the way no matter how long I drove...and the gauge will not even leave C for about 20 minutes. Also, the heat would not actually ever get warm. So yesterday I bought a thermostat and gasket for $6.99 + 0.99 at Autozone. There was a cheaper version, but it was a different temp than the stock value.Anyway, now the heat gets pretty warm in maybe 5-7 minutes, and I am guessing it is warming all the way up now (The temp sensor wire came loose and I cannot figure where it goes).
The job is a little of a PITA because you will likely have to remove a bunch of intake stuff, but once you have access to the thermostat, the job is standard to any car.
