Does the versa SL come w/ the wiring to install the stock sub rockford fosgate?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
remiasz
Hello Im looking to buy the stock rockford fosgate 7 inch sub that comes as an option from nissan. I want to know if the SL versa comes prewired with the sub wiring harness? Thank you for everyones comments.
NODES
Car: 2007 Nissan Versa SL (Blue)
I have seen a few topics on this in the forums. I believe they do but the cost to buy the factory sub and the trim piece is very expensive.
You are better off going with something aftermarket for less.
09SLOwner
Car: 2009 Nissan Versa SL HB
Does anyone have a diagram of which wires are what colors on that harness? I've got an SL as well and would like to use the existing wiring to power my Bazooka tube.
NODES
09SLOwner wrote:Does anyone have a diagram of which wires are what colors on that harness? I've got an SL as well and would like to use the existing wiring to power my Bazooka tube.
the wires are too thin to run as a Power cable for aftermarket sub.
Return to “Versa Technical Discussions”
