Does the SR FPR work on CA with no mods?
Spectre23
Car: S13 CA, 2013 STi, Tony Kart
Just like the title reads... I need to get an adjustable FPR and I read in a really old post that one guy had heard they are interchangable. Is this in fact the case?
Also, Does anyone know of a good cheap place to buy the Nismo?
Will the Nismo go to 53 psi?
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
nissan motorsports usa (NISMO): (310) 538-2610 would probably be my first guess, haha. im such a loser for having that number in my phone..
cant help you with the interchangability question though. hope it does fit...then ill buy one.
- tim
biosehnsucht
FYI Nissan Motorsports (the USA 'brand'/'company') and NISMO not the same... altho Nissan Motorsports carries some NISMO parts, unless that is a # for a REAL NISMO rep...
boost_boy
I use the SR's adjustable FPR regulator and it works just fine. I had to re-angle the return pipe off the F/P regulator, but it bolts to the F/R with no dramas.
Dee
Spectre23
So this is the best price I have found on the Nismo part: http://www.performancenissanpa...id=96
But it says it fits the 240SX, will it also fit the CA fuel rail? It looks the same, but I found on Nissans, thet doesn't necessarily mean jack. Same with most companies I guess.
Spectre23
boost_boy wrote:I use the SR's adjustable FPR regulator and it works just fine. I had to re-angle the return pipe off the F/P regulator, but it bolts to the F/R with dramas.
Dee
Started my reply before this was up. So is the SR one the same as the one I posted? 240SX, SR? Says it fits the NA SR. So I guess it should...
float_6969
Dee, it does or it doesn't bolt on to the F/R without problems? Your sentence was confusing.
r34 gtr
it goes on without any problems. the return pipe from the regulator has to be re-angled to get it to work, but that isnt a tough job.
and that number is for a NISMO representative. you can order all nismo parts and japanese nissan parts by calling that number.
- tim
boost_boy
The same one you see is the one used for the SR, KA and a few more nissan motors. The only reason why I added the fact that i had to re-angle because if you look at the return portion of the regulator, you'll see why. So yes freaks, it will fit your POS CA motors:D. They don't have a listing for a CA18, so that's why I said I'm one from the SR:confused: ..............Poor Ryan. Always:confused:
Dee
boost_boy
Thanks, Tim.......Ryan's a brick:alcoholic ........
Dee
float_6969
DUDE! Read that sentence! It's confusing. Grrr.
r34 gtr
not for a genius like me.
- tim
justinmc
Car: 89 240sx LS swap
86.5 Hardbody pickup
9-2X Aero
A couple of companies make adapters to fit nissan style rails as well.. they let you run an external regulator (such as Aeromotive, etc.). Basically its a flat mounting plate with for the rail with a fitting coming off to run to an external regulator. Works pretty well when I've used it.. cheap too..
boost_boy
You should have known better Ryan:D ! I think you reall know what I meant, I just left out the word "no" before dramas....
Dee
slw240sx
Car: 1990 Ca18det 240sx Hatch
i understood it too. but i also knew the answer to the question before dee chimed in .
r34 gtr
oh, ok. just be cooler than everyone else then! i see what youre trying to do you sneaky basta'd!! im gonna go away now so i can try and think of a witty retort to what you or ryan will say next...
- tim
