Does the SOHC engine rely on oilpressure to maintain tension on the timing chain
slakker
Car: Cars and Comps
????????Please save me from ending my life and answer if you know,??????
slakker
Car: Cars and Comps
ricebike
2002 Quest
2005 Altima
oops, my bad; when i took it apart, there was oil in it; so i guess that little spring is keeping the guide against the chain
so i guess just the hydraulic valve lifters & bearings are relyin' the oil pump's pressure
keep the oil changes in check so they won't "get stuck"
Modified by ricebike at 12:47 AM 10/30/2004
scruffy63
Car: my nissan 240sx
well I can't say for sure but i've been in there and I know it does feel like a spring is in there by itself.
Wraith
Car: 1993 240sx coupe
If the tensioners are anything like the DOHC ones then easy way to tell if pressure driven is check for small port holes on backside of the tensioner if you see them then you know . Just compress the guide side of the tensioner and watch the oil squirt point away from face when you do this .
