Does the s13 sr20det have fuel cut?
turboex
Ok i tried a new boost controler and set it for 15psi, everytime the bost goes over 14psi in first gear the car misses and pops, as if it has fuel cut. I dont think its lean as it does this even with race gas. any ideas?
nlzmo400r
Car: '02 Nissan Altima QR25DE
'93 Nissan 240SX hatch KA24DE
what kind of injectors/pump are you using?, check for clogged rail/injectors/pump/lines
turboex
nlzmo400r wrote:what kind of injectors/pump are you using?, check for clogged rail/injectors/pump/lines
stock, and a 255lph pump. car runs flawless untill over 14psi
vwluv10338
The stock T25 turbo is not really any good over 12-14psi. Your turbo is just maxed out.
Eric
nlzmo400r
that was my next guess, can't flow more air than your turbo will fit
vwluv10338
exactly
turboex
yeah but i hear of guys running 18psi on stock turbos with race gas, hows that work?
nlzmo400r
they may have the t28 turbo, im not really too sure how to respond to that, perhaps your turbo has some kind of problem
vwluv10338
I havent heard of anyone boosting that high on a stock T25 but they could be using a stock T28 which would boost a little higher than a T25.
vwluv10338
nlzmo400r you beat me to it
turboex
ah, so your saying the turbo is just stalling at the psi, causing the motor to not get the air it needs? as the turbo just cant push over that amount? this would make sence
vwluv10338
Exactly, the exact phrase would be the "turbo is past its efficiency range" just to be technical.
turboex
well that explains it, thanks guys, ill just leave the boost at 13psi untill the sc61 goes on. thanks again
nlzmo400r
or just get a big *** turbo !! perhaps a t66 ;), then go on top end supra hunting :)
vwluv10338
what kind of fuel support do you have for the 13psi?
nlzmo400r
he said stock everything, and a 255 lph walbro fule pump
vwluv10338
That was what I thought and 13psi on just a walbro is not good. Turning up the boost without adjusting the fuel is the easiest way to blow up an engine.
turboex
nlzmo400r wrote:or just get a big *** turbo !! perhaps a t66 ;), then go on top end supra hunting :)
the turbo im getting is rated at 580hp, should be fun
nlzmo400r
turboex wrote:the turbo im getting is rated at 580hp, should be fun
waht type of turbo is it?
turboex
vwluv10338 wrote:That was what I thought and 13psi on just a walbro is not good. Turning up the boost without adjusting the fuel is the easiest way to blow up an engine.
This was done on a dyno first, the car runs rich as hell.
turboex
nlzmo400r wrote:waht type of turbo is it?
precision SC61
vwluv10338
Are you going to be running standalone?
Eric
nlzmo400r
god damn that was the quickest reply ive ever seen, also, who makes that ?
turboex
power FC or haltech, have not decided yet. Up to secret service
vwluv10338
I thought you were running stock boost on the dyno, I believe according to your other post.
nlzmo400r
secret service?? is that the code name for the wife?
vwluv10338
nlzmo400r wrote:god damn that was the quickest reply ive ever seen, also, who makes that ?
this thread is about as fast as IM
Eric
vwluv10338
Doesnt Secret Service have the 535rwhp sr20?
turboex
I did run stock boost on the dyno 7psi. But we did one run at 14psi and the turbo pooped, so operator let of gas and told me to check to see what the turbo could push, he said the fuel is there but something else is not. like you guys said turbo just cant do it
turboex
vwluv10338 wrote:Doesnt Secret Service have the 535rwhp sr20?
its here on there sitesecretservices
