Does the oil Bung on oil pan have to be welded?
72nismo
Car: 510 / G35 / Murano
Is there some other way of installing??
Florida240sx
On my friends I used bolts and nuts with lots of gasket maker... But you got to take it off, so ?I would just get it welded...
volcom41488
Car: 1995 240sx se
get the iap kit.. it works good.. i have it nothin leaks out of it
72nismo
How is that installed. I dont want to take the oil pan off if I dont have to.
Florida240sx
Do it once....do it right. Drop the pan. only take about 2hrs to pull it weld and put it back. with a floor jack and by yourself...
72nismo
Yeah your right.By the way were do u get the bung from and what size is it? Thanks
GEO
Car: 95 240sx KA-T
PLEASE OH PLEASE, DO IT THE RIGHT WAY.. I LEARNED THE HARD WAY WHEN WE USED JSUT BOLTS AND GASKET.. LEAKS LEAK LEAKS.. SUCKED. FINALLY GOT IT WELDED AND NO LEAKS... DON'T **** AROUND, JUST GET IT WELDED.
Florida240sx
I got 3 different oil bungs. One that came with iap. and then 2 from oil line kits off the net. Order your feed and return kit at the same time, be anywhere from 80-90 usually
GEO
Car: 95 240sx KA-T
I used EARL ends and a Braided Steel Line.
myRed240
Car: '95 Nissan 240SX with a KA-T!
'07 Audi A3 2.0T DSG
'11 G37S Sedan
GEO wrote:I used EARL ends and a Braided Steel Line.
Can those braided lines be cut to size? I can only find them in 3' intervals and I only need ~20".
Nevermind, I searched a little more and found what I was looking for...
Thanks....
Modified by myRed240 at 6:17 PM 9/27/2006
1995240sxSE
Car: 1991 jeep wrangelr and a 2004 ford taurus
mine is 90% welded and 300% jb welded no leaks. no oil pan removal, jus plasma cutter. btw i blew first 2 motors up! ftw remove and weld!!!!!!
Florida240sx
Yea you cut it..I used a hacksaw. Tape it when you cut because the ends poke out and will stab you lol....
SPIRONIUM
Car: 240RS group 2
The metal composition of the oil pan makes it really easy to weld even for a begginer. I used a 1/2" npt weld on fitting and a hex plug from summit for 5$ then all you need is a step drill bit and a weld machine (or a friend with one or i would trust the welding with any shop) Part#s STF-8807 + EDL-9129
I think its one less thing to worry about if you weld it, just make sure it is water tight before you install
I'm getting ready to install a new KA and i decided that it MAY become turbo in the future, my reason for doing this and then plugging it with the hex bolt. Preventive performance measure
If anyone is in the DC area, bring me the materials and i will do it for you for real
partymonster 975
Car: 03 Maxima SE, 94 Corolla
I'd weld it, to be safe and sturdy.
