does the intercooler pipping get hot when the sr engine is driven????
raul_gotbeat
Car: nissan 240sx
i just wanted to know>>>
T-rev
a little warm, ususally I could keep my hand on it if I wanted to. If you're really flogging it it might get hot to the touch.
edit: this is for the hot pipe, the cold pipe is just that
codyace
Car: S14 w/redtop
Yes, both pipes will warm up.
raul_gotbeat
Car: nissan 240sx
which one is which????
T-rev
the hot pipe runs from the turbo to the inlet of the intercooler. The turbo is hot, therefore the air it compresses is hotter than ambient. The intercooler cools the air from the turbo. The cold pipe runs from the outlet of the intercooler to the throttle body. Its usually warm, but cooler than the hot pipe.
Colder air is denser, so colder air going into your motor at the same pressure as hot air will result in more bang for your buck
raul_gotbeat
Car: nissan 240sx
okay... what about a liquid to air barrel intercooler??? do u know how that works....!!!!!????
codyace
Car: S14 w/redtop
Maximum Boost - Corky Bell
Buy that, read it :D
CMG
Car: 1989 240sx Hatch w/ Redtop
You'd have better luck with a nitrous spray, or maybe even h2o injection.
jessetang
Car: 1995 240sx
raul_gotbeat wrote:okay... what about a liquid to air barrel intercooler??? do u know how that works....!!!!!????
You use water to cool the air. Usually there is an extra radiator somewhere to cool the water. Water to air intercooler is used because water is better than air in cooling.
