Does the engine under cover get used with the STILLEN front fascia for 08 Coupe?
Mr. Music
Car: 2008 Altima Coupe 2.5S CVT w/ Convenience Package
In the family: '02 S15 Spec R, '09 Rogue
I'm ordering Stillen's front fascia, but am wondering if the engine cover pieces under the car get reused or discarded with the installation of the new front fascia? Also, while I'm asking... Ive noticed on some pictures that the corners of Stillen's front fascia stick out a little bit at the wheel arch (pic below). I remember reading that somebody (I think it was adidas2go) drilled a hole in the back side of the fascia and used zip ties to bring it in. Where (more or less) did you make the hole and what did you zip tie it too?Thanks in advance.
Rolling Estonian
Yes the shroud under the car is reused. the only parts that I discarded were the foam behind the stock bumper and two "fin" stock bumber supports
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
Yup, all the under shrouds can be reused.
Also, I drilled a separate hole where the 2 pieces of the fascia connect together on that side. Put the sip tie through it and pulled it to the light housing using a stock bracket on there.
Mr. Music
Alright, cool; thanks guys. For some reason, I couldn't think of the word "shroud" when I was typing the original post, so I looked in the FSM, and it called the shrouds under the car an "Engine Under Cover." I guess Nissan likes to make things complicated.
adidas2go
Yea, even more complicated, if you go to order one, its under radiator support
Mr. Music
Seriously? That's nuts.
maxentropy
Car: '08 Altima Coupe 3.5SE
adidas2go wrote:Yup, all the under shrouds can be reused.
Adidas, can you please supply images of where you drilled holes and zip tied? Did you do anything special to the sideskirts too? They are putting it all on soon.
Also-- the two fin bumper supports are the black pieces of plastic that are in front of the radiator? What exactly did that piece do? Support the oem bumper I guess? heh... Would it help if I left them in or hurt if I took them out?
Thanks!!
maxentropy
BUMP to try and get Adidas's attention!
KGNickl
Car: 2012 Hyundai Sonata
I just used 3 ties w/ out drilling holes to pull in the sides. On the top where the bumper meets w/ the fender the where 3-4 small holes in the bumper. I looped a zip tie through them and behind the fender/bumper there is a plastic thing that I looped the zip tie around. I then pulled them tight. Then put the screw back in that holds the bumper and pushed back the fender well liner. Took 5 minutes.
Also for the bumper I thought the 3m tape was stupid, so I drilled holes through the 2 pieces that use the tape and then used zip ties. I'm not a fan of 3m tape holding parts together together that has pressure pulling them apart. I only like 3m tape for things like moldings.
I also had to buy longer bolts for the front points. The bolts they gave were too short. I could grind down the plastic where the holes where drilled under the bumper, but I didn't have a grinder tool that would fit into the area and it was easier just buying longer bolts.
Also there was pretty extensive prep work that had to be done on the bumper. There was a couple hairline cracks where the grill meets w/ the bumper and tons of little pin holes all over the bumper.
So basically it you are buying this bumper and want it to look good its not as easy as scuff, paint, and mount. The instructions make you think this if you read, but it also says professional install is recommended (which a professional will see all the flaws and fix them....and charge you $$$$). So my experience was it fits nearly perfect (except the corner bumper area pushing out sometimes). The prep consisted of scuff, clean, primer, filling all the holes and fixing a couple hair line cracks, sanding, priming again to make sure cracks where fixed, painting, some pin holes came through after the paint....., sand, fill, prime, paint. Bought (2) longer bolts and used zip ties to hold parts of the bumper together (parts that where supposed to be held together with 3m tape). Then mounted the bumper and used zip ties to fix the corner issues. Overall the bumper looks and fits great, but took some work to get it perfect. You could just scuff, paint, and mount but the results will be ok at best.
maxentropy
KGNickl, thanks for the info-- do you think you can post some pictures of where you drilled/tied the fascia down? I've got to take my car back to the bodyshop so they can install the sideskirts (they just got painted) and I'll have them ziptie the fascia while I am there if you or someone can provide images.
Cheers!
