Might be because you're driving slower than normal, driving slower = worse mpg.lilojoj wrote:now im only getting around 17 and i drive like a grandma.
+1 Zerep lol. I never go the speed limit around here where I live. (No tickets so far!)Zerep wrote:the cold is supposed to help but i get 21mpg from my 2.5 ill admit i drive like a retard brrmm "doing 90 in a 65"
AHH! you just jynxed ur self!! Knock on wood, knock on wood! hahaalteredbeast wrote:
yes it does, a lot.first, gas stations use different gasoline during the winter time. it's a lot worse then summer gasoline.second, cold engine doesn't run as efficiently as a warmed up engine. oil is thicker at lower temps and more energy is wasted moving components.third, you waste more time warming up your car in the winter then you do in the same. standing still with car running = bad mpg.lilojoj wrote:does the cold affect mpg?
LOL you may be correct, since you are from Florida, when it's really hot in the summer the engine can loose power, and since you don't need to defrost your car, you probably do get better MPG! I know the race track times in the Winter are way better in Florida for those reasonsxfactor0707 wrote:I guess i was wrong.
