Does the '95 J30 have a rear oxygen sensor?
vishesh
Car: '95 Infiniti J30
So here's the backstory: my exhaust pipes (see diagram) are rusty/loose and are leaking exhaust. Environmental hazard, yes, but doesn't really affect the car's operation (except it seems a bit more sluggish, though this could be for other reasons). However, they make the car REALLY LOUD (think lion-roar-loud), and I need to replace them both (left and right sides). I think it's labeled as #2 on the parts diagram under the exhaust parts group. Anyway, I'm shopping around for either (1) new aftermarket exhaust pipes + catalytic converter, OR (2) used, but original Infiniti pipes. Sellers are asking if I need the rear oxygen sensor, and I'm not sure what to tell them. Supposedly the '96 J30's have a rear oxygen sensor port in the exhaust pipes, but I'm not sure if the 95's do. I don't even know whether my car needs/has a rear oxygen sensor. Any thoughts? Diagrams / pictures of J30 underbody would be especially useful. I'm a visual guy.
Thanks!
coolyun_98
Car: 1993 J30 11,7000kM
From http://sparkplugs.com/, it seems like 95 J30 does NOT have rear O2 sensors. You should double check with others...
gr8scott72
Car: 1994 Infiniti J30t
vishesh wrote:So here's the backstory: my exhaust pipes (see diagram) are rusty/loose and are leaking exhaust. Environmental hazard, yes, but doesn't really affect the car's operation (except it seems a bit more sluggish, though this could be for other reasons). However, they make the car REALLY LOUD (think lion-roar-loud), and I need to replace them both (left and right sides). I think it's labeled as #2 on the parts diagram under the exhaust parts group. Anyway, I'm shopping around for either (1) new aftermarket exhaust pipes + catalytic converter, OR (2) used, but original Infiniti pipes. Sellers are asking if I need the rear oxygen sensor, and I'm not sure what to tell them. Supposedly the '96 J30's have a rear oxygen sensor port in the exhaust pipes, but I'm not sure if the 95's do. I don't even know whether my car needs/has a rear oxygen sensor. Any thoughts? Diagrams / pictures of J30 underbody would be especially useful. I'm a visual guy.
Thanks!
You do know that you can look under your own car and see for yourself?
vishesh
har har scott. problem is, i wouldn't know what i'm looking for.
:p
yodawill2000
Car: 94 Infiniti J30
Looks alot like a Spark plug but it will be in your exhaust system.
gr8scott72
yodawill2000 wrote:Looks alot like a Spark plug but it will be in your exhaust system.
and it will have a wire harness on it.
vishesh
gr8scott72 wrote:and it will have a wire harness on it.
any chance you could point out (maybe on the diagram below) where the oxygen sensor would be? i just need a place to start looking. thanks
gr8scott72
The rear o2 sensor will be downstream, or behind (towards the rear of the car) the cats.
