Does the 2016-2017 QX70 premium grill fit 2013 FX37 with no modification?
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
jinfiniti
Car: 2013 Fx37
New member. Thanks.
jinfiniti
Car: 2013 Fx37
Wow ... not a single person knows?
EdBwoy
Hello, jinfiniti.
Welcome to NICOclub. I am not sure, and with it not being my money, I hate to send you in that direction, but to me it sure looks like it should fit. Typically, Nissan makes only one mid-generational fascia change for their models, and it seems like the hourglass outline of the grille was it for this generation.
jinfiniti
Car: 2013 Fx37
Hi EdBwoy, thank you for trying to help. We have a lot of QX70, FX37 and FX35 owners here so I assume someone might know. My current grill is peeling paint and is looking ugly. Would like to replace the grill asap. First, I would like to confirm if it fits or not.
z16chevelleguy
Car: 2017 QX70- 2013 G37 Coupe Journey-2007 Corvette convertible-1998 GMC 3500 4 X 4 -1965 Chevelle SS
jinfiniti wrote:
Thu Mar 22, 2018 1:20 am
Hello,
I own a 2017 QX70. Have you had your grill out? Pretty simple operation. Maybe 10 minutes to remove.Here is what I can do to help you.
1) Remove the clips holding the cover over the radiator
2) There are five (5) nuts holding the grille.
3) After removing the nuts pull from the top and the grille should come right out
4) Provide some measurements and I will remove my grille and check your measurements against mine. Overall length and height of grille, distance top and bottom of the 5 nuts.
I can email you pictures of the grille front and back when I remove it.I cannot promise you when I can do this is the only negative factor.
Larry
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
