whiterps13 »
https://forums.nicoclub.com/whiterps13-u9007.html
Wed Oct 24, 2007 1:33 pm
The drving effect? Ummmm...
Lets start off with the offsets. 17x9+35 is going to hit coilovers and be sunken as hell. Run this setup with 20mm spacers and a 235/40/17. Tons of people run 17x9+20 w/ a 235/40/17 all the way around..
The driving effect... Wider front tires will change the characteristics of your car. First off, theyre going to track like hell over grooves and imperfections in the road. They will pull you from side to side unless the road is completely flat and perfect. Who cares though?
With good tires your car is also going to handle much better (DUH!). Since you arent staggering, the car should remain pretty neutral in terms of over/understeer.
