In searching I've seen a post that indicates the side mirror can be accessed by just removing the triangular plastic cover rather than the entire door panel. I did try to remove that but wasn't too sure and didn't want to break anything. Found this forum and thought I would ask here as I'm sure someone has the information
I was also trying to see how to get the mirror cover off on the replacement unit but not able to see the cover clips when tilting the mirror up.
This is a 2012 rogue, the mirror has the camera if that makes any difference.
Thanks
