does s14 come with lsd?
br2819
i heard that they do and if they do will it fit on a s13? also did the s13 come with a lsd?
DriftBandit
Car: this is my 3rd 240sx
Yes some s14's came with an lsd, It would have to be one with ABS though those two go hand in hand. Some s13's came with LSD also but again they usually come with the ones with ABS and super hisac. The s14's lsd will fit on a s13 but the rear plate will have to be changed, probobly easiest to swap internals.
xyster
Car: '00 Prelude
an s14 with abs doesn't necessarily have a VLSD. My 95 SE had abs, but didn't have one. The S14 vlsd will fit on an S13 with a swapped rear cover and new axles or output shafts. The S13's have a 6-bolt, 3-pair pattern. The S14's have a 5-bolt star pattern. You also need to modify the front mounting points slightly, and get some large washers. It sounds hard, but it's really very easy...you can do all that in a few hours.
